[Ju...] Posted January 2 Share Posted January 2 I have 4-sided star with really short arms which cause it to shank out during qualification. Is there any way to prevent the tactile scanning from going to the equator so that it does not shank out? Link to comment Share on other sites More sharing options...
[Ma...] Posted January 2 Share Posted January 2 I think if you reduce coverage and not using tensor, then it should do the trick. Link to comment Share on other sites More sharing options...
[Ju...] Posted January 2 Author Share Posted January 2 what do you mean not using tensor? Link to comment Share on other sites More sharing options...
[Ma...] Posted January 2 Share Posted January 2 You can define how you will calibrate your probe - pasive, tensor, dynamic tensor. I also found you posted a question in another post. That is not working? Link to comment Share on other sites More sharing options...
[Ju...] Posted January 2 Author Share Posted January 2 Well we would like to just stick to using the 30mm sphere that we use for all our styli qualifications just to keep it simple. We only have two modes to use for qualification and if we use the geometry re-qualification it actually does use the sphere coverage correctly and will not go to the equator but at the same time it only probes 6 single points and I do not feel that this is a good enough process to qualify the sphere. Scanning would be better but when we use that method it always goes to the equator and ignores the sphere coverage. Link to comment Share on other sites More sharing options...
[Ju...] Posted January 2 Author Share Posted January 2 probes 6 single points and I do not feel that this is a good enough process to qualify the "Styli" Link to comment Share on other sites More sharing options...
[Ma...] Posted January 2 Share Posted January 2 That "Standard" option - what's there? I am wondering if you can do manual path - i remember when i was doing qualification for disk i had to do manual path - defining own points. Perhaps this would be the way. But if you have smaller sphere, then it would be better to use that. Link to comment Share on other sites More sharing options...
[Ju...] Posted January 2 Author Share Posted January 2 Maybe it could. Uhm I don't know it's locked. Thanks for the help tho. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 5 Share Posted January 5 Use an 8mm Sphere. 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted January 6 Share Posted January 6 I was told that using probes smaller than ~10% of the diameter of the calibration sphere is not a good idea, but cannot find any official documentation of this. (We use an 8mm sphere for all our smaller probes and it seems to work well) Link to comment Share on other sites More sharing options...
[Ky...] Posted January 6 Share Posted January 6 I don't know that I heard the 10% rule (not to mention, that would mean qualifying a 3 mm on a 30 mm reference sphere wouldn't be good and I've never had issues with that). My general rule of thumb is anything 1 mm or below (sometimes 1.5 and below) should be qualified on a smaller reference sphere (usually the 8 mm I think). The sphere coverage doesn't affect the scanning part of passive qualification (it does on the point taking part and the geometry requal), so that isn't really a solution I think. I would think the only real answers is either a longer stem on the stylus or a smaller reference sphere. 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted Monday at 06:52 PM Share Posted Monday at 06:52 PM You can try lowering Taper Angle Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 07:27 AM Share Posted Wednesday at 07:27 AM For the "passive stylus qualification" CALYPSO will always use 180°, no matter what you type in. For the geometry re-qualification lowering the angle below 180° does work. Best Regards Marcel Link to comment Share on other sites More sharing options...
[Br...] Posted Thursday at 09:09 PM Share Posted Thursday at 09:09 PM You will need a smaller reference sphere. As Marcel mentioned above, for a passive sensor, you have to run qual passive at least once. To do this, you have to have a smaller sphere. Link to comment Share on other sites More sharing options...
