[Ri...] Posted Thursday at 12:28 PM Share Posted Thursday at 12:28 PM I am trying to check if a feature is active and assign a different stylus tip. I am not sure if using "if Plane3==true" is what I need or should use, it appears to calculate in the PCM Editor. if PN=="00-887298" if "Plane3"=true Datum_B_tipA=="Down" Datum_B_tipB=="Down" else Datum_B_tipA=Datum_B_tip3 Datum_B_tipB=Datum_B_tip5 endif endif Any assitance with this is appreciated. Link to comment Share on other sites More sharing options...
