[Ri...] Posted January 8 Share Posted January 8 I am trying to check if a feature is active and assign a different stylus tip. I am not sure if using "if Plane3==true" is what I need or should use, it appears to calculate in the PCM Editor. if PN=="00-887298" if "Plane3"=true Datum_B_tipA=="Down" Datum_B_tipB=="Down" else Datum_B_tipA=Datum_B_tip3 Datum_B_tipB=Datum_B_tip5 endif endif Any assitance with this is appreciated. Link to comment Share on other sites More sharing options...
[An...] Posted January 16 Share Posted January 16 if "Plane3"=true Does not seem to do anything. That is just saying the word Plane3 when in quotes is set to true. But unfortunately I can't think of a way or a syntax to interact with a feature. Not saying there isn't but I would have to dig into see if any syntax does exist. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 19 Author Share Posted January 19 The code "if "Plane3"=true" was just pseudo text to imply what I am looking to achieve. Link to comment Share on other sites More sharing options...
[Mi...] Posted January 19 Share Posted January 19 What do you mean with "check if a feature is active"? I don't understand what you want to achieve. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 20 Author Share Posted January 20 When Calypso changes to a different feature I assume there is some internal flag we can catch at the time the feature name is activated for measuring. We can see the next feature to be measured at the top of the Calypso screen just before the measurement starts. Link to comment Share on other sites More sharing options...
[Ch...] Posted January 22 Share Posted January 22 Richard, I think we need more info : What would cause 'plane 3' to be active or not ?, this could help us solve it. Also by chance, is plane 3 always a primary datum of the base alignment for example ? This might help with the solution as well, if it is just a random feature not tied to an alignment etc, it could be more challegning. Link to comment Share on other sites More sharing options...
[Ri...] Posted Friday at 12:58 PM Author Share Posted Friday at 12:58 PM Please sign in to view this quote. It's used for a measurement. I run from Features, not Characteristics. Features are generally run in the order they are created (placed in the feature list) unless a feature has an alignment other than base alignment then the alignment related features will be run prior to the feature in the list order. It is a feature tied to a dimension or PCM in dimensions and or other features, not used in any alignments. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted Friday at 01:38 PM Share Posted Friday at 01:38 PM I'll see what I can find, so if plane H is active you want to use #3 & #5 stylus ? I would initially think, there should be an easier way based on a Part# or Part Config parameter instead. However seeing the lengths you've went to on other PCM programs, we'll give you the benefit of the doubt. 🙂 it should be something to the effect of (not actual commands just theorizing) : myFeat="Plane H" if activeFeat=myFeat then doSomething endif Link to comment Share on other sites More sharing options...
Popular Post [Mi...] Posted Tuesday at 01:15 PM Popular Post Share Posted Tuesday at 01:15 PM You can retrieve the actual feature name with baseSystem().machine.inspection.settings.actualMEObj.identifier and may put plugin_preFeature_pcm.txt (with the desired code) into the inspection directory if baseSystem().machine.inspection.isRunning==true then myFeat="Plane H" activeFeat=baseSystem().machine.inspection.settings.actualMEObj.identifier if activeFeat==myFeat then doSomething endif endif 4 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted Tuesday at 01:51 PM Share Posted Tuesday at 01:51 PM Nice work Michael ! I have limited access currently to PCM at my new company. Link to comment Share on other sites More sharing options...
[Ri...] Posted 13 hours ago Author Share Posted 13 hours ago (edited) Please sign in to view this quote. Thank you for this. Examples like this are needed for my AI project. I will test this later. if baseSystem().machine.inspection.isRunning==true then myFeat="Plane3" activeFeat=baseSystem().machine.inspection.settings.actualMEObj.identifier if activeFeat==myFeat then Datum_B_tipA=="Down" Datum_B_tipB=="Down" else Datum_B_tipA=Datum_B_tip3 Datum_B_tipB=Datum_B_tip5 endif endif Edited 13 hours ago Link to comment Share on other sites More sharing options...
