[Bl...] Posted January 9 Share Posted January 9 I'm sure it's very simple, but I can't seem to figure out how to export a report as CSV file. Is there anyone that knows that can help me? Link to comment Share on other sites More sharing options...
[Ky...] Posted January 9 Share Posted January 9 If you are looking for help with CALYPSO exporting to CSV, unfortunately it isn't possible. The closest CALYPSO supports is the table files (which are tab delimited). That usually works in most circumstances, but I can't guarantee it will for you. Link to comment Share on other sites More sharing options...
[Na...] Posted January 12 Share Posted January 12 If the software is Zeiss Inspect, use this function: https://techguide.zeiss.com/en/zeiss-inspect-2026/article/cmd_internal_sys_export_gom_xml_by_report_pages_csv.html Link to comment Share on other sites More sharing options...
[Ri...] Posted January 23 Share Posted January 23 (edited) PowerShell script to convert (Save as) an open excel file to CSV. (AI generated) This should work at the end of your CMM program. Create a batch file named "inspection_end.bat" @echo off REM Run PowerShell script from the same folder powershell -ExecutionPolicy Bypass -File "%~dp0inspection_end.ps1" exit /b Create a ps1 file (PowerShell) named "inspection_end.ps1". Use the code below. param( [Parameter(Mandatory = $true)] [string]$OutputCsvPath, [string]$WorksheetName ) # Excel constants $xlCSVUTF8 = 62 # CSV UTF-8 (Excel 2016+) $xlWorksheet = -4167 try { # Attach to running Excel $excel = [Runtime.InteropServices.Marshal]::GetActiveObject("Excel.Application") if (-not $excel) { throw "Excel is not running." } $workbook = $excel.ActiveWorkbook if (-not $workbook) { throw "No active workbook." } # Select worksheet if specified if ($WorksheetName) { $sheet = $workbook.Worksheets.Item($WorksheetName) if ($sheet.Type -ne $xlWorksheet) { throw "Specified sheet is not a worksheet." } $sheet.Activate() | Out-Null } # Suppress prompts $excel.DisplayAlerts = $false # Save As CSV (active sheet only) $workbook.SaveAs($OutputCsvPath, $xlCSVUTF8) Write-Host "Saved as CSV:`n$OutputCsvPath" } catch { Write-Error $_.Exception.Message } finally { if ($excel) { $excel.DisplayAlerts = $true } # Release COM objects foreach ($obj in @($sheet, $workbook, $excel)) { if ($obj -and [System.Runtime.InteropServices.Marshal]::IsComObject($obj)) { [void][System.Runtime.InteropServices.Marshal]::FinalReleaseComObject($obj) } } [GC]::Collect() [GC]::WaitForPendingFinalizers() } Both of these files should be in your CMM program folder (The program you are running). Edited January 23 missed an instruction Link to comment Share on other sites More sharing options...
