[Te...] Posted January 12 Share Posted January 12 Hello, I'm experiencing an unusual issue. I have a CAD model loaded, and when I attempt to measure a circle (nothing out of the ordinary), the probe approaches the feature prematurely and makes contact with a plane before reaching the hole. Could this behaviour be caused by a problem with the model, or is there another likely source of the issue? Link to comment Share on other sites More sharing options...
Popular Post [Co...] Posted January 12 Popular Post Share Posted January 12 Hey Terry, I'm not sure but it might just be the plane in the way that needs to be moved? Sorry, it's been a long day here and I needed a laugh! 4 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted January 12 Share Posted January 12 (edited) A quick check would be to make sure the inside/outside switch (round circle at top of feature) is selected correctly. I've seen features taken from a cad model default to OD when it is actually an ID. Also, features checked with an angled probe should use a clearance distance the same as the retract distance with the retract distance calculated to the center of the hole.. Most features don’t use a clearance distance but, on angled probe features, it must be used or the probe will not travel exactly at the A1/A2 angle when (for example) going into or coming back out of a hole. Edited January 12 1 Link to comment Share on other sites More sharing options...
[Ke...] Posted January 12 Share Posted January 12 Is this happening in simulation, or on a physical machine? Based on description the first thing I would check is the ID/OD toggle for the circle, this happens semi-frequently where the ID hole is set to OD, and tries to move through the part to approach from the outside of the feature instead of inside 2 Link to comment Share on other sites More sharing options...
[Ow...] Posted January 13 Share Posted January 13 Please sign in to view this quote. Planes are important. My wife wanted plain toast for breakfast 🙂 2 Link to comment Share on other sites More sharing options...
