[Ra...] Posted January 12 Share Posted January 12 Is it possible to have one scanning template that would work on two different Scanboxes? We would like to be able to have a single scan template for two Scanboxes that are configured exactly the same. Link to comment https://qualityforum.zeiss.com/topic/25533-single-scan-template-for-two-scanboxes/ Share on other sites More sharing options...
[Na...] Posted January 15 Share Posted January 15 Hi Randall, you can use the same project template (inspections, measuring paths, reports etc.) with different scanboxes. The project templates are usually stored on a network drive which can be defined in the preferences. Nanno Link to comment https://qualityforum.zeiss.com/topic/25533-single-scan-template-for-two-scanboxes/#findComment-144633 Share on other sites More sharing options...
