Hide Cp/Cpk if there is only one sided tolerance
Hey everyone,
quick question: I got a code from Zeiss that’s supposed to hide Cp/Cpk results if we have a one-sided tolerance. Right now, it only works when the nominal is 0.0000. Is there a way to fix this, or is this the limit of PiWeb?
The Code : ${if Equal(ToString(Qdb.Characteristic(2120)), "Natürliche Grenze") then false else true}
Thanks in advance!
Hi, this is expected behaviour, as you have defined a lower tolerance. If you also want to filter the characteristics with a lower tolerance of 0, you can use the following expression: ${if AnyOf(Equal(ToString(Qdb.Characteristic(2120)), "Natürliche Grenze"), Equal(Qdb.Characteristic(2112), 0)) then false else true}
  • Thank you! 1
  • 2 weeks later...
