PCM problem
I have a parametric program for a family of 5 sizes. Visually the scan doesn't match where it should be on the model.
I've double checked everything (I think). It's got to be something simple. Any ideas? PCM_1 shows in wireframe the scan
inside the outer wall. Should be on the wall. PCM_2 is the solid view and PCM_3 is the para file showing the X variable.
I must be overlooking something simple. Any ideas? BTW, I'm running this is simulation.
1. Does the model displayed match the part size measured?
2. Is dispersion turned on (since nominals and actuals differ)?
3. Have you set a display scale (overheight) factor for deviations?
Dispersion is under Extras/Settings/Measurement/Simulation. If it's on you should also see a yellow warning sign in the CNC start window.
What I meant by 3. is magnification (I was struggling with the correct translation 😉). You can access it by right-clicking in the CAD view when a feature window is open, or in the CAD evaluation dialog. Dispersion together with high magnification can result in seemingly shifted actuals.
The times I have seen this, its usually one or the other for nominals values.
If using a circle on a plane, check the Strategy for nominal values (My example works in the Z axis).
If using a polyline in a plane, you also have to check nominal values. Regardless of the axis or angle of a plane, the polyline nominal for Z should be Zeros.
This is why I preach about nominals and vectors being perfect.
Besides the more likely causes that were already posted above, one oops that has caused this for me was using an improperly qualified probe (was set to reference sphere 1 when 2 was actually probed), or a different probe was attached then what was defined.  Or, a bent probe shaft.
