[Ro...] Posted January 18 Share Posted January 18 (edited) I bought 3 new plates at the end of 2025, snuck them in with some leftover budget. Put one together today and it wont click into place on the head There are 2 little balls on the base plate that need to lock in to the head, but the ones i bought are in the wrong location. the head has 3 "holes" but 1 is filled in with what looks like epoxy. Can i press out the ball from its current location and move it over to the spot that it needs to be in? Additionally, there is a sticker in the box that says the base needs to be Activated, is that a new thing? My CMM computer is not connected to the network, so there is no internet on this machine. Edited January 18 Link to comment Share on other sites More sharing options...
[Ma...] Posted January 18 Share Posted January 18 Your "current" is TL3 and your new one is TL1 Your head seems to accept tl2,3,4 2 Link to comment Share on other sites More sharing options...
[No...] Posted January 19 Share Posted January 19 (edited) Regarding the need to activate: Each plate (and by the way many other electornic components of the CMM) has an ID chip under the black area, and the ID of that chip must be registered (activated) correctly in the controller. Depending on your firmware version and the manufacturing date of the plate the IDs might already be activated - or not. If not, there's a tool named Device Activator that you can download from the portal or the link given, which performs the activation. Edited January 19 2 Link to comment Share on other sites More sharing options...
