[Fe...] Posted January 19 Share Posted January 19 there is a characteristic copable of calculating the concentricity between the centre of holes and a cylinder reference? Link to comment Share on other sites More sharing options...
[Fe...] Posted January 19 Author Share Posted January 19 Link to comment Share on other sites More sharing options...
[Ma...] Posted January 19 Share Posted January 19 Is it pitch circle from n of holes? Your picture is not helping much - i am not sure on which element is concentricity used. Link to comment Share on other sites More sharing options...
[Jo...] Posted January 19 Share Posted January 19 I also don`t have a good idea of the situation from your picture. In general you need something with a common center to use concentricity. Otherwise you can use a position. Link to comment Share on other sites More sharing options...
[DW...] Posted January 19 Share Posted January 19 (edited) Please sign in to view this username. From the snippet I am guessing you have a pattern of through holes on the large face where the pattern must be concentric to A (as a circle) within a tolerance zone of 0.01 (no idea the units). If that is the case, construct a circle feature from the pattern of through hole circles by recalling them into the bolt hole circle. Create a concentricity characteristic where the feature is the bolt hole circle and the first datum is A as a circle. Edited January 19 Link to comment Share on other sites More sharing options...
[Fe...] Posted January 22 Author Share Posted January 22 Link to comment Share on other sites More sharing options...
