[Ch...] Posted 8 hours ago Share Posted 8 hours ago Templates for Standard Probes in Stylus System Creator Are there any templates of standard probes that I can upload to Stylus System Creator? Star probes, etc. I've never really worked with Planner/simulation; it would just be faster for visualization. Link to comment Share on other sites More sharing options...
[Ka...] Posted 5 hours ago Share Posted 5 hours ago Hi, Do your own Template.. 🙂 You can define your sensor and a standard stylus. Then save it as your template. It is relatively easy to swap one stylus for another. The database contains many buttons from the Zeiss shop. Unfortunately, however, the database is very old and some stylus are missing. In this case, you can only contact Zeiss and they will send you the data to import into the database after a while. However, you can put together many Stylus combinations yourself in the generic area. Have fun with this Software... regards Karsten 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted 4 hours ago Author Share Posted 4 hours ago Hallo Karsten, ich wollte eigentlich clever und faul sein ob jemand ein paar Beispiele dazu hat. Muss ich mal bei Gelegenheit welche zusammen bauen. Danke. Link to comment Share on other sites More sharing options...
[Jö...] Posted 2 hours ago Share Posted 2 hours ago Hallo Marti, diese Dateien kannst du im Stylus Creator importieren. Ich hatte irgendwann mal Zeit ,und habe ein Paar erstellt. Vielleicht hilft dir das. Gruß Jörg Konfig_01.ssc Konfig_05.ssc Konfig_06.ssc Konfig_07.ssc Konfig_11.ssc Konfig_16.ssc 1 1 Link to comment Share on other sites More sharing options...
