[Pa...] Posted January 21 Share Posted January 21 Hello, I'm trying to create a characterstic table but this characteristic table I want it to be as a table list see photo wavetable.gra.Mine goes on the next page....Does anyone know what has to be done?Also tried the page layout as table layout but no luck. Link to comment Share on other sites More sharing options...
[Kl...] Posted January 21 Share Posted January 21 You need special PCM syntax to create more then 30 harmonics for a table at PiWeb.Also advaced handling for the customized PiWeb report is necessary. Please post more info, so I can send costomized PCM ans PiWeb. 33.pdf Link to comment Share on other sites More sharing options...
[Pa...] Posted January 22 Author Share Posted January 22 (edited) Hello Klaus. I've attached the measurement plan inspection.What it needs,the harmonics table list of the 3 waveness to add it near the fourier analysis plot as it is in the measurement report you attached. I'm using the Calypso 8.0 version the plan inspection is in 6.2. IR.TR1.KEROLA.7z Edited January 22 Link to comment Share on other sites More sharing options...
[Dr...] Posted January 22 Share Posted January 22 Hello, I have a question regarding the Suppression Level parameter in the plot, and I would appreciate your assistance. Is it possible to modify this limit directly via PCM, or is it necessary to use custom templates with different values in order to keep the desired limit constant? Additionally, in the image below, it can be observed that the Suppression Level is set to a value of 1.0. Link to comment Share on other sites More sharing options...
[Kl...] Posted January 22 Share Posted January 22 Hello Dragut It's a fixed value for the Waviness template and you can only modify it manually 😞 Also most of time the input shows 0.000, because it's rounded to integer 😞 A possible value at your example could be 10nm ==> input = 0.000010 ==> shown = 0.0 Therefore I prefer customized graphic for parts, which longer under production. Klaus Link to comment Share on other sites More sharing options...
[Kl...] Posted January 26 Share Posted January 26 Hello I've put an inspection, result PFT and the userfield.ini into the topic. The customized PiWeb reports are stored inside the inspection. The parameter file is adapted to the simulation, smaller RTA tolerance Other optimizations 1 - Correct nominals inside surface => PCM values according to this nominals 2 - Number of calculated according to evaluation range 1500 harmonics 3 - Some tolerances were set to zero ? 4 - Collect the reports into one PDF by GhostScript 5 - Stylus configuration by planner (subdirectory) 6 - Customized userfield.ini for special record head data 7 - The important PCM you will find inside the waviness evaluation and the addiional characteristics 8 - The are new parameter at the para.txt, which is loaded by PCM command inside the pre-settings of the inspection Inspection should run in simualation. Please send me and actual.zmp after the test one a CMM Please test it carefully and Good Luck 🙂 Klaus 13.pdf IR_TR1_KEROLA.zip userfields.ini Link to comment Share on other sites More sharing options...
[Pa...] Posted January 27 Author Share Posted January 27 Thank you very much for your support 🙏.I've just managed it to test it on simulation not on CMM yet but everything It works smoothly. Link to comment Share on other sites More sharing options...
