[Sh...] Posted 12 hours ago Share Posted 12 hours ago I'm having an issue with Measure Points when running Subsequent Evaluation. It's taking about 5-6 minutes to load and run a single .zmp and I think it might be tied to a 2d Curve because I'm using Recall Feature Points in features generated from the curve. Anyone familiar with this or have any solutions? Link to comment Share on other sites More sharing options...
[Ch...] Posted 12 hours ago Share Posted 12 hours ago Shawn, howdy, are meas points on local hard drive or network ? I've had similar issues when they are on network. Shouldnt take this long though unless you have a lot of curves/freeform with a lot of points and Ca evaluations. Link to comment Share on other sites More sharing options...
[Sh...] Posted 11 hours ago Author Share Posted 11 hours ago i've tried both network and local, unfortunately didn't matter 😞 Link to comment Share on other sites More sharing options...
[Cr...] Posted 11 hours ago Share Posted 11 hours ago I found if you have a lot of files (or they are big files) in the idmeaspoints folder within the program folder it will slow down the loading of measured points. When this happens, I create a new folder within the measurement plan folder and move older files from idmeaspoints into that folder. If I ever need to load measured points from a part that I've moved, I'll just move it back into the idmeaspoints folder. 1 Link to comment Share on other sites More sharing options...
[Pa...] Posted 11 hours ago Share Posted 11 hours ago In addition, a measurement plan with LOTS of points or with graphic displays absolutely take a much longer time to process. Link to comment Share on other sites More sharing options...
