Search distance
Hello.
Is it possible somehow to set a bigger search distance, especially when measuring pitch/MdK? The problem I have is that we have some parts with excentricity error fc around 0,5 mm. Gear stops measuring with message "probing not found".
Edited
Wrong spell
I should add that we measure with rotary table (integrated) and Vast Gold probe head. Calypso 7.8 and Gear 7.2.
Hi, in general the searching distance possibilities are limited in the case you describe.
First you can try to activate "tooth-thickness correction" at feeding-in (attachment).
Alternatively you could think about measuring in self-centering double-flank contact mode?
Maybe this works better for this case with high eccentricity deviations.
  • Like! 1
