[M1...] Posted Tuesday at 01:49 PM Share Posted Tuesday at 01:49 PM (edited) Hello. Is it possible somehow to set a bigger search distance, especially when measuring pitch/MdK? The problem I have is that we have some parts with excentricity error fc around 0,5 mm. Gear stops measuring with message "probing not found". Edited Tuesday at 01:49 PM Wrong spell Link to comment Share on other sites More sharing options...
[M1...] Posted Tuesday at 04:24 PM Author Share Posted Tuesday at 04:24 PM I should add that we measure with rotary table (integrated) and Vast Gold probe head. Calypso 7.8 and Gear 7.2. Link to comment Share on other sites More sharing options...
[Ro...] Posted 15 hours ago Share Posted 15 hours ago Hi, in general the searching distance possibilities are limited in the case you describe. First you can try to activate "tooth-thickness correction" at feeding-in (attachment). Alternatively you could think about measuring in self-centering double-flank contact mode? Maybe this works better for this case with high eccentricity deviations. Link to comment Share on other sites More sharing options...
