[Cl...] Posted January 28 Share Posted January 28 I have a parametric program. A family of 5 sizes. Geometry identical, but size changes in X & Y. I have created nominal curves (recalled into freeform surfaces) for each size. Is there a way to insert the right size constructed FFS into the chosen size by way of an "if" statement or some other PCM condition or formula? My PCM knowledge is limited. Link to comment https://qualityforum.zeiss.com/topic/25655-pcm-curves/ Share on other sites More sharing options...
[Ch...] Posted January 28 Share Posted January 28 Clarke , I think there should be. I know with PCM you can clear and load CAD models which are generally required for FFS. If curves are the same only X + Y changes, may be better to tie them to an alignment, Perhaps can be done by selecting a "mini-plan" at start for each configuration. 1 Link to comment https://qualityforum.zeiss.com/topic/25655-pcm-curves/#findComment-145197 Share on other sites More sharing options...
[Cl...] Posted January 28 Author Share Posted January 28 That worked. Never entered my mind something that simple. 1 Link to comment https://qualityforum.zeiss.com/topic/25655-pcm-curves/#findComment-145229 Share on other sites More sharing options...
[Cl...] Posted January 29 Author Share Posted January 29 Sorry. The mini-plan option worked. 1 Link to comment https://qualityforum.zeiss.com/topic/25655-pcm-curves/#findComment-145279 Share on other sites More sharing options...
