[Cl...] Posted 17 hours ago Share Posted 17 hours ago I have a parametric program. A family of 5 sizes. Geometry identical, but size changes in X & Y. I have created nominal curves (recalled into freeform surfaces) for each size. Is there a way to insert the right size constructed FFS into the chosen size by way of an "if" statement or some other PCM condition or formula? My PCM knowledge is limited. Link to comment Share on other sites More sharing options...
[Ch...] Posted 17 hours ago Share Posted 17 hours ago Clarke , I think there should be. I know with PCM you can clear and load CAD models which are generally required for FFS. If curves are the same only X + Y changes, may be better to tie them to an alignment, Perhaps can be done by selecting a "mini-plan" at start for each configuration. 1 Link to comment Share on other sites More sharing options...
[Cl...] Posted 12 hours ago Author Share Posted 12 hours ago That worked. Never entered my mind something that simple. 1 Link to comment Share on other sites More sharing options...
