[Fe...] Posted January 29 Share Posted January 29 is it possible to copy a program and change only one element? i have two practically identical piece, only one size changes and i wouldn't want to redo the pregram again. is it possible? thanks Link to comment Share on other sites More sharing options...
[Jo...] Posted January 29 Share Posted January 29 You can just copy the *.zinspect file, rename it and start implementing the changes. Link to comment Share on other sites More sharing options...
[Mi...] Posted January 29 Share Posted January 29 You can also utilize the "Save As" function. With the project opened go to File->Save As Give it a new name I.E ZEISS Block 2 instead of ZEISS Block 1, hit Save You are now within the new project you just saved as, so you can make the necessary changes while the original project stays untouched. Link to comment Share on other sites More sharing options...
