about Orient Image
Hello all,
I need to import the other image into actual measurement series and  orient  it with using orient image command. The image that is imported is one of the  measurement images but i have modified by marking some shapes before importing the template.
When i try to orient the image, i need to select at least 5 points to be able to align the image. Is there any other way to orient or align the image in same projection angle with the original version of the measurement image without selecting points? I need to make a script to be able to do that and it takes too much time to achieve lower pixel deviation by matching points.
Many Thanks,
Canset
