chr.txt files
Hello all,
I may not be using the correct search words for this if it has been discussed in the past. However, my issue today is when Calypso is creating the chr.txt files that I use in QC-Calc and also use in a compile excel base system that on GD&T with LMC/MMC it is reporting the number prior to the calculation. I've looked around in quite a few places and cannot seem to find a good solution/work-around for this to have the after-calculation spit on these files instead or in addition to. Can anyone offer some insight onto this?
Thanks in advance.
  • Like! 1
I probably don't have the answer, but is the CHR file not showing the correct info, or is QC-Calc not pulling the correct answer? Where is the error seen?
  • Like! 1
When you say "reporting the number" prior to calculation, are you talking about the tolerance? Or the actual vaule?
Also, are we talking about MMB? Or just MMC?
