[Ca...] Posted 11 hours ago Share Posted 11 hours ago I've seen these callouts before; I understand what the intent is. How would I check this in Calypso? Link to comment Share on other sites More sharing options...
[Ri...] Posted 10 hours ago Share Posted 10 hours ago Can you use Flatness instead? Otherwise there is not directly easy way to achieve this. Link to comment Share on other sites More sharing options...
[Ca...] Posted 10 hours ago Author Share Posted 10 hours ago Not really? It's a few contour surfaces. Link to comment Share on other sites More sharing options...
[Pe...] Posted 9 hours ago Share Posted 9 hours ago I've come across a similar callout on some of our contoured parts. As far as I know, there isnt a way to do that in calypso. I think there might be in other softwares which is why someone got it in their head that is was ok to add it to the print. The solution we came up by working with the customer was a specific number of .010 "box" profiles that were located at certain areas to ensure that there was sufficient overlap of our squares, and then one .015 profile that encompassed the entire surface. Link to comment Share on other sites More sharing options...
[Ca...] Posted 9 hours ago Author Share Posted 9 hours ago Well, thanks anyway. Maybe someone will have a suggestion. Link to comment Share on other sites More sharing options...
[Ch...] Posted 9 hours ago Share Posted 9 hours ago rare callout, they should just apply a stack up and let you do a total measurement and report, but if I had to do this I would just measure multiple 0.75 x 0.75 grids and report multiple profiles. Sure there could be many 'overlap' areas, but it's best we can do... Link to comment Share on other sites More sharing options...
