[Da...] Posted Tuesday at 07:59 AM Share Posted Tuesday at 07:59 AM Hello, Does anyone know how I can export the points of a curve, for example? And if, once exported, I can convert them to different formats that can be viewed in CAD, for example? Thank you very much. Link to comment Share on other sites More sharing options...
[Na...] Posted Tuesday at 08:23 AM Share Posted Tuesday at 08:23 AM Hello David, which Software are you using? Link to comment Share on other sites More sharing options...
[Da...] Posted Tuesday at 08:47 AM Author Share Posted Tuesday at 08:47 AM Please sign in to view this quote. Hi Nanno, Are you referring to the Calypso version of the software or the software I want to load the points onto later? I want to load the points on a different computer. Link to comment Share on other sites More sharing options...
[Da...] Posted Tuesday at 09:15 AM Author Share Posted Tuesday at 09:15 AM Please sign in to view this quote. Hello again, here's the situation: The software on the computer where I have the CMM is: WINDOWS 10 IoT Enterprise LTSC version 21H2. The software on the computer where I want to work with the extracted points is: WINDOWS 11 Enterprise version 23H2. The Calypso version I have is 7.8.12. Is this what you're asking for? Thank you very much. Link to comment Share on other sites More sharing options...
[Na...] Posted Tuesday at 10:24 AM Share Posted Tuesday at 10:24 AM Hi David, this forum is for all kind of Zeiss Softwares, so it was not clear it's about Calypso. I will move this thread to the Calypso subforum. Link to comment Share on other sites More sharing options...
[Da...] Posted Tuesday at 11:23 AM Author Share Posted Tuesday at 11:23 AM Please sign in to view this quote. Okay, sorry, I didn't know that... Thank you very much. Link to comment Share on other sites More sharing options...
[Jü...] Posted 23 hours ago Share Posted 23 hours ago Please sign in to view this quote. Hello David, you can export the points of a curve as DXF. To do this, right-click on the curve and select “Export points.” In the window, you can then adjust the settings and finally select the path for the file. If you want to have multiple curves in one file, call up the points of all curves in a freeform surface and then export the points of the surface. Link to comment Share on other sites More sharing options...
[Da...] Posted 19 hours ago Author Share Posted 19 hours ago Please sign in to view this quote. Thanks so much, Jürgen! I've already been able to export them; now I just need to be able to load them into AutoCAD... hehe. Can you help me with that too?😉 Link to comment Share on other sites More sharing options...
