[PA...] Posted June 9, 2021 Share Posted June 9, 2021 MY SCAN AND ALIGNMENT WON'T PRELAIGN Link to comment Share on other sites More sharing options...
[Ra...] Posted June 11, 2021 Share Posted June 11, 2021 You have your CAD model and your mesh and they won't align...Did you try making the search time longer or giving them a nominal point to help them find each other? Link to comment Share on other sites More sharing options...
[Be...] Posted June 14, 2021 Share Posted June 14, 2021 In general: If the 'Prealignment' is not working, use a different alignment strategy. For example: Alignment by three points Local Bestfit afterwards (may be with a bigger maximum distance) For further main alignments: Check that the 'Parent alignment' is your local bestfit to have a good starting point. Hope this helps?! Regards, Bernd Link to comment Share on other sites More sharing options...
