[Ho...] Posted February 21 Share Posted February 21 When I attempted to log in in Zeiss Quality Suite, I encountered an error as "Failed to log in" below. Does anyone know to resolve this issue? Link to comment Share on other sites More sharing options...
[Ri...] Posted February 23 Share Posted February 23 (edited) There should be a search bar at the top right of the screen, type in a part number and it should take you to the correct page where you can then perform product searches. Edited February 23 Link to comment Share on other sites More sharing options...
[St...] Posted Wednesday at 02:10 PM Share Posted Wednesday at 02:10 PM I’m getting the same error message as HoangD when I try to sign in to Zeiss Quality Suite. Is there a solution for this? @Richard Stanich: I can’t make sense of your proposed solution. Was it related to the issue mentioned above? Link to comment Share on other sites More sharing options...
[DW...] Posted Wednesday at 04:19 PM Share Posted Wednesday at 04:19 PM Please sign in to view this username. Same issue here. My guess is it has something to do with Windows Update that happened last night across the world. 1 Link to comment Share on other sites More sharing options...
[Ja...] Posted Wednesday at 07:08 PM Share Posted Wednesday at 07:08 PM I am having the same issue. Any solutions? Link to comment Share on other sites More sharing options...
[Ni...] Posted Wednesday at 10:07 PM Share Posted Wednesday at 10:07 PM Attempting to setup a new ATOS Q station and I'm unable to due to not being able to download Zeiss Inspect Optical 3D as it fails with the login error. Is there a work around or hot fix for this? Link to comment Share on other sites More sharing options...
[La...] Posted Thursday at 01:43 AM Share Posted Thursday at 01:43 AM I got the same issue here. Failed to log in. Link to comment Share on other sites More sharing options...
[Ch...] Posted Thursday at 07:56 AM Share Posted Thursday at 07:56 AM Thank you very much for reporting the login issue. Our development team is currently investigating this problem internally. If you suspect an issue with the latest windows update it might be an option to roll this back. In the meantime, if the login via ZEISS Quality Suite (ZQS) is not working for you, please use the ZEISS Portal as an alternative, especially for downloading software. To help us analyze and resolve the issue more quickly, we kindly ask you to provide support data from ZEISS Quality Suite via your local ZEISS support organization. They will forward the data to us for further investigation. Thank you for your patience and support while we work on a solution. Link to comment Share on other sites More sharing options...
[Ro...] Posted Thursday at 08:56 PM Share Posted Thursday at 08:56 PM Hello, same problem, no login possible at Quality Soite Link to comment Share on other sites More sharing options...
[Fa...] Posted Friday at 01:24 PM Share Posted Friday at 01:24 PM same issue here. Tried to unistall the latest KB installed yesterday, not working either Link to comment Share on other sites More sharing options...
[Ph...] Posted 5 hours ago Share Posted 5 hours ago (edited) Hello, We are experiencing the same issue. After attempting to update ZEISS Inspect Optical 3D Version 2026.3.1.9, the software became unusable. We hope it will be resolved soon so that we can continue using it. Thank you in advance Edited 5 hours ago Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago Hello, we have the same problems - ZEISS Quality Suite login and installs not working. Nobody is fixing it. Link to comment Share on other sites More sharing options...
[To...] Posted 28 minutes ago Share Posted 28 minutes ago Hello, we are still trying to solve this problem with high priority. The root cause is not any Windows update. Thank you for your patience in the meantime. As mentioned in https://qualityforum.zeiss.com/topic/25913-failed-to-log-in-error-when-clicking-on-log-in-in-zeiss-quality-suite/?do=findComment&comment=149194, the ZEISS Portal is an alternative for some tasks, especially for downloading software. Link to comment Share on other sites More sharing options...
