[yo...] Posted yesterday at 12:35 AM Share Posted yesterday at 12:35 AM I recently tried a demo of QuickSurface and in the areas where QS and Zeiss inspect the one thing I was impressed by was the ability in QS to autodetect symmetry by loosely defining a plane with a few points approximately along the symmetry. Then it pretty accurately picks up the symmetry and gives you a reference plane for it. Is there any way to do this in Zeiss that I have just missed? If not I think it would be an awesome feature and I would think relatively easy to implement. Zeiss can align parts based off features. I would imagine it could be done with the same algorithms by essentially looking for features across a part instead of between two parts. Link to comment Share on other sites More sharing options...
[Jo...] Posted yesterday at 07:36 AM Share Posted yesterday at 07:36 AM Hi, I dont know about loosly but you can construct a symmetrie plane of course. Then there is also a mirror feature that should help getting both planes for that fast. Techguide seems down atm, so i cant give you a link. And you could write script for that if you really use that a lot. Link to comment Share on other sites More sharing options...
[yo...] Posted 21 hours ago Author Share Posted 21 hours ago Please sign in to view this quote. If you mean a symmetry plane based off other planes created from features then you need features on the part that could be used to construct those planes. For example it would be easy to create centerline planes on a cube by creating a best fit plane on each face and then a symmetry plane between them. But if a part has very organic geometry it could be difficult or impossible to pick up clearly defined geometry to precisely find the center, wheras the algorithm in QuickSurface is able to look at all the points and essentially find a best fit centerline just like Zeiss does best fit features for other things. Link to comment Share on other sites More sharing options...
[Jo...] Posted 13 hours ago Share Posted 13 hours ago (edited) What do you want his for? You can create a plane out of very "organic" stuff. Thats what fitting algorithms are for. Inspect does this aswell. Just construct a fitting plan select all points of your mesh and choose a normal and you got your symmetrie, when you choose Gauß. Edited 13 hours ago Link to comment Share on other sites More sharing options...
