[Br...] Posted February 24 Share Posted February 24 I’m looking for input from anyone who has implemented an iterative bore-measurement approach in Calypso 2022 that isolates the lands only when establishing a datum from a rifled barrel. On our previous Hexagon CMMs (PC-DMIS, non-scanning), we established the primary datum feature from the lands by measuring a 4-point circle. After the initial measurement, we used an IF/THEN routine: If the measured diameter fell outside a defined range (indicating contact on grooves), the alignment would rotate by a set increment. The circle would then be remeasured. This loop continued until all four contact points landed only on the lands. That resulting circle defined the bore diameter. We repeated the process at the opposite end of the barrel and constructed the datum axis from those two circles. With our Zeiss machines, we’re currently scanning and using a maximum inscribed circle to define the bore. While this works, I’m interested in recreating something closer to the iterative “land-only” approach described above—ideally using Calypso logic, PCM, or another built-in method. Has anyone done something similar in Calypso 2022? Specifically: Rotating an alignment iteratively based on measured diameter feedback Forcing point selection to land features only Or scripting a looped remeasurement routine to converge on a land-derived circle Any guidance, examples, or best-practice suggestions would be greatly appreciated. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 24 Share Posted February 24 Most of it only with PCM to have a comfort. For others you have to do much of a work by copying features and so on. I would recommend using base alignment to have iterative result and better / safer definitions of nominal paths / points to scan. Link to comment Share on other sites More sharing options...
[Ze...] Posted February 24 Share Posted February 24 How about using maximum/minimum coordinate on your scanned circle to find the high/low spots. Then use that info to refine subsequent alignments. Link to comment Share on other sites More sharing options...
[Cl...] Posted February 24 Share Posted February 24 (edited) What about using fixturing to physically clock the geometry? This would allow for an alignment on one of the lands. I would think this would allow you to scan only the surfaces you needed. We do something very similar here. Physically clocking some very complex geometry so we can avoid certain surfaces to measure Datum circles. Edited February 24 Link to comment Share on other sites More sharing options...
[Pa...] Posted February 26 Share Posted February 26 If your geometry allows, you could use self-center points like in a spline to find the start of a land. You could then trace the correct nominal helix with line scans. This would find the start of the land in just a few seconds. Link to comment Share on other sites More sharing options...
[Ke...] Posted February 26 Share Posted February 26 What sensor are you using for this? The methodology may be similar, but an active system like the Vast Gold or Vast XT can use a feature called flyscan which can be quite useful for things like rifling. As a general method, create a circle with a short partial arc strategy (enough to hit 1 land whether it starts in a groove or not, but not much more than that) near one end of the barrel. Set that strategy to use single points (you may be able to just scan based on the depth of your grooves and size of probe), and set your point density/spacing enough that you’ll definitely get a good point on a land, but not so many it takes forever to run. From this feature extract a point on the land (most likely using a max point of that circle feature). Use that point as the clocking feature in an alignment, so that one of the axes points directly through the land. Use this alignment as the alignment for your datum measuring feature, so that way the start of the strategy will always adjust to be on the land that it found previously. From here you have options for how to actually check the datum feature. You could flyscan a circle,do a 360 circle set to single points with a number of points equal to your land count so each point will hit a land(then rotate by the Twist RateXDistance to do another measurement further along the barrel), or potentially use a cylinder feature with several helixes matched to the twist to traverse the entire barrel scanning the land depending on what you need. Link to comment Share on other sites More sharing options...
[is...] Posted March 27 Share Posted March 27 Same as Zen and Pat methods using self centering point and min/max coordinate. Scan the bore across lands and grooves using a line feature, use maximum coordinate (for ID) to get the farthest point from the center of the bore, then create a self centering point using the farthest point. Use the self centering point feature on your alignment in planar rotation. Rotate your alignment to get the land. In the attached pic, I have an external spline with 64 teeth that is why I used minimum coordinate. Link to comment Share on other sites More sharing options...
[Ch...] Posted March 30 Share Posted March 30 There is an interesting strategy that I use on helical twin screw rotors. It involves using the start alignment to establish the primary axis and Z origin, then using a base alignment that is blank except for the rotation datum. In both examples, we have helical part. In both examples we want to loop the rotation until we find a certain lobe/land. The benefits to this strategy is that you can only loop the base alignment(which is only one point). Since its only one point, even looping it many times doesn't take long. Now, we add further alignments after the base alignment that help us out. I would recommend you use a curve best fit alignment that only rotates about the center axis near the top, then measure all other features back to that best fit alignment. This will allow you to evaluate any 'twist' of the rifling. Iterative Alignment.pdf 3 Link to comment Share on other sites More sharing options...
[Ja...] Posted April 1 Share Posted April 1 Chad - That's an interesting approach to doing an Iterative Alignment. Looking forward to trying it. Thanks. Link to comment Share on other sites More sharing options...
[Ch...] Posted April 1 Share Posted April 1 Please sign in to view this quote. It works very nice when you don't want to iterate the entire base alignment. Most people say you shouldn't have blanks in your base alignment, but that's not necessarily true. If values in the base alignment are blank, then it will pull from the start alignment, and if those are blank, then it pulls from the machine coordinates. The order of precedent is Base Alignment>Start Alignment>Machine Coordinates. 1 Link to comment Share on other sites More sharing options...
