ACIS Socket Already in Use with Gear Pro 2024 and Calypso 2023
I am running into an issue with trying to run Gear Pro 2024 with Calypso 2023.  When I launch Gear Pro 2024, I get a message say "ACIS Socket Already in Use".  See attached. Any idea why this message appears?
Also, when I click "OK" to the message "ACIS Socket Already in Use", I can start inputting the main geometry for the gear, but the "DISPLAY GEO" button to generate the CAD model is greyed out.  See attached.
getting same issue at one of our site with GP 2021.
There is a KB article .. https://portal.zeiss.com/knowledge-base?id=1353838
However ours is set up exactly as shown.
We are on windows 10, and I'm thinking a windows update could have blocked this port or more likely I.T. security. It appears there is an inbound rule to allow it to open on ours, however when I ping open ports I see Calypso is listening but 9996 or Gear Pro acis is not open or listening.
Following to see any progress, but our next step is to upgrade to 2023 and Win 11, then our I.T. Dept can help us.
Out of curiosity do you have any issues with running multiple parts? I can seem to only run one part then Gear Pro seems to crash and I have to shut down PC. A restart doesn't even fix it.
Good luck !
wellp,   uninstall / reinstall no worky here.
I tried repair first, back'ed up the GearNT folder. got rid of entire acis folder then tried  uninstall /reinstall
I even managed to make sure port 9996 is open using cmd code to get around IT security, it seemed to work and show it was open listening,
 services file is mapped right to port GEARACIS 9996/tcp
I could see if Calypso and Gear Pro were using same version of ACIS, however our GR is v31 and Calypso is v32 Acis.
I do have the GEARACIS        9996/tcp in this file.  Even tried reentering it a second time.  Still getting the same error "ACIS socket already in use!"
Gentlemen, which colors have the ports in the setup dialog?
Can you please provide the zipped logging folder after you activate the yellow marked items and after you get the error message?
Please provide this via you local GEAR PRO support team.
Thank you.
yes I did,
 Our I.T. Dept is still looking into, I have a feeling it is Windows 10 and or a security rule; but Calypso is unaffected.
 As mentioned we did do a repair then an uninstall from Gear Pro installer and I confirmed it did removed the acis folders from GearNT.
Reinstall still behaves the same.
We will likely end up trying to update to Win11 and a newer version of Gear Pro.
 Thanks,
See attached logging.zip file and screenshots for the "Components" and "Logging" tabs in GearPro 2025.
Thanks for helping out with this issue.
logging.zip
Thank you for the screenshots.
Nothing that can be changed or influenced by us as an operator.
Please send the logging.zip to your local ZEISS support team as they have to create a ticket for investigation on this.
Also give them the information of your system.
Windows 10 or 11?
GEAR PRO 2023, but which exact version? 7.0.????
Thank you again.
