[Da...] Posted February 25 Share Posted February 25 Hello friends, When I run a program in Calypso, that program is duplicated in the directory. The idmpoints are only saved in the duplicate program, while in the original program that idmpoints folder has disappeared. What could be the reason? Thanks. Link to comment Share on other sites More sharing options...
[Ch...] Posted February 25 Share Posted February 25 Hi David, first why is the program double? You can define the path of the IDM-Points. Link to comment Share on other sites More sharing options...
[Da...] Posted February 25 Author Share Posted February 25 Please sign in to view this quote. Hi Christian, It's a strange thing that's been happening since an update I had done, and it might be related to program backups. But it's exactly as I described: once I run a program, a new program with the same name is created in the same file, so the ID/M points for both programs are different. That's what's bothering me. Otherwise, I can delete the new program and nothing happens; it's still in the original file. Sorry for how I'm explaining it; it's a bit confusing and maybe I'm not explaining it well. Link to comment Share on other sites More sharing options...
[Ch...] Posted February 25 Share Posted February 25 David, no problem, everything's fine. I'm not familiar with that phenomenon. Take a look here and see if something is activated incorrectly. 1 Link to comment Share on other sites More sharing options...
[Da...] Posted February 25 Author Share Posted February 25 Please sign in to view this quote. If you look at the screenshots, the first screenshot shows the new duplicate program that's created with an idmpoint. The second screenshot shows the original program, which doesn't have an idmpoint. If I then delete the duplicate program, I lose that idmpoint, and my directory keeps filling up with duplicate programs. It has something to do with the path where I'm loading them from, but I can't find the solution. Link to comment Share on other sites More sharing options...
[Da...] Posted February 25 Author Share Posted February 25 Please sign in to view this quote. Hi again Christian! I've got it working! I activated the test plane instead of the directory, and it fixed what I wanted. The problem is that the first time it didn't work because I hadn't done it with the master user... Thank you so much! You've been a huge help. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted February 25 Share Posted February 25 Your welcome 🤘🏻 2 Link to comment Share on other sites More sharing options...
