Duplicate programs
Hello friends, When I run a program in Calypso, that program is duplicated in the directory. The idmpoints are only saved in the duplicate program, while in the original program that idmpoints folder has disappeared. What could be the reason? Thanks.
Hi Christian, It's a strange thing that's been happening since an update I had done, and it might be related to program backups. But it's exactly as I described: once I run a program, a new program with the same name is created in the same file, so the ID/M points for both programs are different. That's what's bothering me. Otherwise, I can delete the new program and nothing happens; it's still in the original file. Sorry for how I'm explaining it; it's a bit confusing and maybe I'm not explaining it well.
David, no problem, everything's fine. I'm not familiar with that phenomenon. Take a look here and see if something is activated incorrectly.
If you look at the screenshots, the first screenshot shows the new duplicate program that's created with an idmpoint. The second screenshot shows the original program, which doesn't have an idmpoint. If I then delete the duplicate program, I lose that idmpoint, and my directory keeps filling up with duplicate programs. It has something to do with the path where I'm loading them from, but I can't find the solution.
Hi again Christian! I've got it working! I activated the test plane instead of the directory, and it fixed what I wanted. The problem is that the first time it didn't work because I hadn't done it with the master user... Thank you so much! You've been a huge help.
