[Jo...] Posted February 25 Share Posted February 25 Is it possible to get information from an external PCM file into Piweb report? I have an external pcm file that gets probe information and validates it... before you ask I know i can use the probe qual inside a program or use result element also... we didn't do that setup so i do not want to go back into 1400 programs to do it.... I probably can use a new header variable do set my variables to, but with multiple probes being used in the programs, i really do not know how to set that up on a loop. What my file contains is a loop with the probes used in the program (based on another text file we put in the inspection folder) and checks for our probe qualification data. so if a program has three probes it would be PROBE(1), PROBE(2), PROBE(3) and what ever variable I have to check ( getProbe(Probe(1)).stdProbeDev for an example). Link to comment Share on other sites More sharing options...
[Do...] Posted March 4 Share Posted March 4 Hi, this is not possible. It is a new requirement to write the probe data as name-value pairs into the database. You are welcome to submit your request in My Voice ZEISS Portal Link to comment Share on other sites More sharing options...
[Jo...] Posted March 6 Author Share Posted March 6 I actually got it to work... sort of.... I created my PCM variable, did all my editing inside PCM then used a setRecordHead() variable to my variable. Used a single text box with the header data variable i created and it appears on the report. I get an error message now in calypso before i click on anything (not just inside a program)...see attached... and when i run a program. this is not just in CALYPSO 2025 but also in 2020. The variable reads correctly and is setup, but as soon as I set it to a header variable, after the 1st run, it gives me the error.... for every single line of the variable. Link to comment Share on other sites More sharing options...
[Jo...] Posted March 9 Author Share Posted March 9 I got 99% of it to work. The problem is with the error message. I found a work around but it only works if i do it manually. The variable is stored in the protheadpara file, so when i delete that i get no message and program runs. I tried to do the deletion with PCM in the inspection_end_pcm.txt file... and it does delete it, but when it comes back, i get the error message, but when i cancel and manual delete...no message.....Am I loosing my mind? Link to comment Share on other sites More sharing options...
[Jo...] Posted March 10 Author Share Posted March 10 ok ... round about way... most likely a better way but found a solution .... I read the protheadpara file into a listfile, then made a loop looking for the line that had my variable name. the counter variable would be that line minus 1... so i set the same loop again with the exit at the counter minus 1 while setting each line to a variable. in the inspection_end_pcm.txt file... i simply deleted the file, then used addFile with the new variable.... programs now run with no errors. messy but it works. Link to comment Share on other sites More sharing options...
