PROBE DATA
Is it possible to get information from an external PCM file into Piweb report?   I have an external pcm file that gets probe information and validates it... before you ask I know i can use the probe qual inside a program or use result element also... we didn't do that setup so i do not want to go back into 1400 programs to do it....   I probably can use a new header variable do set my variables to, but with multiple probes being used in the programs, i really do not know how to set that up on a loop.
What my file contains is a loop with the probes used in the program (based on another text file we put in the inspection folder) and checks for our probe qualification data. so if a program has three probes it would be  PROBE(1), PROBE(2), PROBE(3)  and what ever variable I have to check ( getProbe(Probe(1)).stdProbeDev  for an example).
Hi,
this is not possible. It is a new requirement to write the probe data as name-value pairs into the database. You are welcome to submit your request in My Voice ZEISS Portal
