[Jo...] Posted February 25 Share Posted February 25 Is it possible to get information from an external PCM file into Piweb report? I have an external pcm file that gets probe information and validates it... before you ask I know i can use the probe qual inside a program or use result element also... we didn't do that setup so i do not want to go back into 1400 programs to do it.... I probably can use a new header variable do set my variables to, but with multiple probes being used in the programs, i really do not know how to set that up on a loop. What my file contains is a loop with the probes used in the program (based on another text file we put in the inspection folder) and checks for our probe qualification data. so if a program has three probes it would be PROBE(1), PROBE(2), PROBE(3) and what ever variable I have to check ( getProbe(Probe(1)).stdProbeDev for an example). Link to comment Share on other sites More sharing options...
[Do...] Posted Wednesday at 08:09 AM Share Posted Wednesday at 08:09 AM Hi, this is not possible. It is a new requirement to write the probe data as name-value pairs into the database. You are welcome to submit your request in My Voice ZEISS Portal Link to comment Share on other sites More sharing options...
[Jo...] Posted 15 hours ago Author Share Posted 15 hours ago I actually got it to work... sort of.... I created my PCM variable, did all my editing inside PCM then used a setRecordHead() variable to my variable. Used a single text box with the header data variable i created and it appears on the report. I get an error message now in calypso before i click on anything (not just inside a program)...see attached... and when i run a program. this is not just in CALYPSO 2025 but also in 2020. The variable reads correctly and is setup, but as soon as I set it to a header variable, after the 1st run, it gives me the error.... for every single line of the variable. Link to comment Share on other sites More sharing options...
