Machine hitting limits.
Does anyone know why my Contura would be hitting the limits outside of the clearance planes?  They are set correctly, the box looks correct yet when I execute program after first plane is measured, the movement goes 6 inches outside clearance plane and alarms out.
Hi Jeffrey,
do you have a screenshot from your "Alarm" ? Are you to close to the travel limit of the CMM?
I think I figured it out.  In my Plane 2 and Plane 3 for alignment I changed the clearance plane to CP+Z in all 3 and it worked.  I am using a 3x50 probe.
If you have a part close to machine limits and you have VAST XT for example and probes which is shorter than probe head, then it will move further.
Please specify your setup further 🙂
