[je...] Posted February 25 Share Posted February 25 Does anyone know why my Contura would be hitting the limits outside of the clearance planes? They are set correctly, the box looks correct yet when I execute program after first plane is measured, the movement goes 6 inches outside clearance plane and alarms out. Link to comment https://qualityforum.zeiss.com/topic/25939-machine-hitting-limits/ Share on other sites More sharing options...
[Ch...] Posted February 25 Share Posted February 25 Hi Jeffrey, do you have a screenshot from your "Alarm" ? Are you to close to the travel limit of the CMM? Link to comment https://qualityforum.zeiss.com/topic/25939-machine-hitting-limits/#findComment-146745 Share on other sites More sharing options...
[je...] Posted February 25 Author Share Posted February 25 I get a hardware limit stop. Possible alignment issue? Not sure. Photo.pdf Link to comment https://qualityforum.zeiss.com/topic/25939-machine-hitting-limits/#findComment-146749 Share on other sites More sharing options...
[je...] Posted February 25 Author Share Posted February 25 My part is at least 5+ inches from machine limits where it sits. Link to comment https://qualityforum.zeiss.com/topic/25939-machine-hitting-limits/#findComment-146751 Share on other sites More sharing options...
[je...] Posted February 25 Author Share Posted February 25 I think I figured it out. In my Plane 2 and Plane 3 for alignment I changed the clearance plane to CP+Z in all 3 and it worked. I am using a 3x50 probe. Link to comment https://qualityforum.zeiss.com/topic/25939-machine-hitting-limits/#findComment-146757 Share on other sites More sharing options...
[Ma...] Posted February 25 Share Posted February 25 If you have a part close to machine limits and you have VAST XT for example and probes which is shorter than probe head, then it will move further. Please specify your setup further 🙂 Link to comment https://qualityforum.zeiss.com/topic/25939-machine-hitting-limits/#findComment-146763 Share on other sites More sharing options...
