"Select Inside Sphere" not remembering point when copying project
Hello, I have an application that requires small variations on the same Inspect project. I am therefore just replacing the CAD model and redefining a few features. Most of the rest of the project then calculates automatically. However I have one feature that uses the 'Select Inside Sphere' function for selecting data for a fitting element. The center of this sphere is defined as a constructed point. See image below.
However, when I copy the project and replace the CAD, it doesn't reapply this selection when I recalculate the project. The point it was made with respect to calculates no problem but the selection simply doesn't happen. There are many repeat features like this so it makes copying a project far more complicated / time consuming. More importantly, it is making it difficult to hand this project over for colleagues to edit.
I have also had similar problems using the 'select above plane' and 'select by curve' functions. Am I using these incorrectly? Is this a limitation of the software or a bug? Is there an alternate method?
Any help greatly appreciated 🙂
