[Ma...] Posted February 25 Share Posted February 25 Anyone ever have this message re-occur several times over months? What cause it and how do I fix it? Link to comment Share on other sites More sharing options...
[Ma...] Posted February 26 Share Posted February 26 Hi Matthew, it looks like there has been made a change within the Probe Tab, please double check if the RDS -> XXT is selected or if it has been changed to "Zeiss Fixed Mounting" If you have an RDS on your CMM and change it to another system it could overwrite your config (and delete all Stylus Systems) if you confirm it twice in these windows. Since you have 2 Contura Tabs on the bottom, make sure that only 1 has the automatic connection enabled. Best Regards Marcel Link to comment Share on other sites More sharing options...
[Ma...] Posted February 27 Author Share Posted February 27 Thank you for the response, I got a hold of Zeiss, and they are saying since this is re-occurring, it may be an issue with the board inside the RDS cage...whatever that means. But usually, I can restart and it will connect or in a couple cases I have had to just delete the probe data and reconfigure the settings. But I do appreciate the feedback, Marcel. Link to comment Share on other sites More sharing options...
