Error Message
Hi Matthew,
it looks like there has been made a change within the Probe Tab, please double check if the RDS -> XXT is selected or if it has been changed to "Zeiss Fixed Mounting"
If you have an RDS on your CMM and change it to another system it could overwrite your config (and delete all Stylus Systems) if you confirm it twice in these windows.
Since you have 2 Contura Tabs on the bottom, make sure that only 1 has the automatic connection enabled.
Best Regards
Marcel
