excell
You have to turn on excel reporting for the plan you are running. Resources, define report, default report/ warning limit, then choose the whichever Characteristic template you want to use. The Characteristic.xlt would be if you are using older versions of Excel that use the .xls format. Characteristics .xlsm would be for newer versions of Excel using the .xlsx format. These templates can be changed to suit your needs. There are some guides if you do a bit of google searching, on how to do that. Here is an older guide, but it can at least give you an idea of what you can do.
Calypso Excel Reporting.pdf
https://qualityforum.zeiss.com/topic/25951-excell/#findComment-147015
  • 3 weeks later...
Just my opinion, but you're going to have better luck doing this outside of Calypso.
I use 'Report_End.bat" to call a python script that copies the _chr.txt table files and move them to a folder.  Then use Python scripts to update various excel sheets.  Its not that bad, with AI, everyone's a programmer now.
https://qualityforum.zeiss.com/topic/25951-excell/#findComment-148187
 It is surprising even with project automation tools like Codex and Claude Code how many people do not have any interest in jumping into the scripting/automation game. Even in very technical fields, some people just have no interest in learning a little bit that could help them a lot. I was into scripting long before AI hit the stage, but man does it take you from crawl/walk to a full sprint.
 Chad is right, manipulating the data outside of the Calypso environment is going to be easier, faster, more customizable. Search the forums for "PowerShell" and you will see some examples of scripting that can more than likely automate the task(s) you are trying to accomplish.
https://qualityforum.zeiss.com/topic/25951-excell/#findComment-148197
 If you haven't use OpenAI's Codex or Anthropic's Claude Code yet, it will blow your mind. It creates scripts from nothing except an idea and recursively fixes the code until it functions correctly. No copy paste, no manual fixes, no "Would you like to..?" prompts. It can search your local environment for solutions first, and then go grab whatever it needs from online repositories if you let it. And then you can peak under the hood at the code and it's just... insane.
  • Thank you! 1
https://qualityforum.zeiss.com/topic/25951-excell/#findComment-148272
