[Ri...] Posted February 26 Share Posted February 26 Hi to all. I have a Cylinder with an eleven bore pattern and each has three scans. Can I extract each individual scan separately? If I use "Cylinder1(1)" it includes all three scans, I want the one at the entry of the Cylinder. Then I would set up another Circle for the Middle and a Circle at Depth. Is this possible? Or do I have to create three individual Circles for each depth of scan? Link to comment Share on other sites More sharing options...
[Pa...] Posted February 26 Share Posted February 26 Create your circle, recall measured points. Check "show all features in patterns / loops. Select your cylinder with a single left click. Right click on that cylinder and select "open" from the context menu. You can now select any of the paths you wish. 2 Link to comment Share on other sites More sharing options...
[Ri...] Posted February 26 Author Share Posted February 26 Thank you, I could not recall how to do it. No I am not old. Yes I am...😅 1 Link to comment Share on other sites More sharing options...
