[Ow...] Posted February 26 Share Posted February 26 Would somebody care to elaborate on this and also explain how the diagram alignments work on the K-charts? I looked in the manual to no avail, and while it seems fairly intuitive, I'm looking for some examples with explanations. Hoping somebody has some documentation on them. TIA Link to comment Share on other sites More sharing options...
[Ch...] Posted February 26 Share Posted February 26 Owen, Howdy, sure, these are mainly to tell Gear Pro how to align the K-Tolerance Band to the actual data, there are a few ways. By default with a K-Chart I think the general rule of thumb is the 'highest point of the trace/measurement' typically aligns to the top of the tolerance band. What is shown as upper tolerance option above. There is also the option to align the trace/measurement data of the lowest point which will then 'become' the lower tolerance band alignment. Reference Line is to any arbitrary 0 line to attempt to center the trace I presume. Zero point I think is to start the band where the trace starts at zero it appears. You can also restrict the alignment range allowed so as it looks for a hi point or low point of trace, you can restrict the area it searches for, this is typically reduced to the main profile area around the center /PD allowing for some end relief etc. In most cases unless otherwise specified - upper tolerance should be fine, if unsure consult your Engineering Dept. Good luck ! 2 Link to comment Share on other sites More sharing options...
[Ow...] Posted Monday at 05:04 PM Author Share Posted Monday at 05:04 PM Dear Chris Gear Rotolo,(middle name meant as a compliment) Thank you for elaborating on the subject. I'm currently in the early stages of a functional analysis that is focusing on using chemically accelerated Isotropic SuperFinishing to remove Micropitting from case/induction hardened gear teeth and prolong the life of the gears. A lot of the older gear nomenclature on the gears I'm using are controlled with K-charts. Even though the New AGMA 2015-1-A01 established in 2003 no longer recommended using the "K" chart for profile and lead evaluations, it is still being used in the automotive and agriculture field I work within, seen a 2024 print the other day using it. The problem with the “K” chart is that any profile or lead within the defined “K” area could be an acceptable gear. Some of the newer prints restrict the alignment to be with the high point tangential to the reference line, and defines allowable pitch and index deviations, the older prints do not. When checking worn gears, short of topographical evaluation, having the diagram alignment selections is imperative. I just wanted to make sure there wasn't anything affected that is not intuitively implied. I am struggling with K-charts appearing on leads and I haven't updated to Gear-Pro 2025 yet, but I hope it fixes the lead K-charts. Link to comment Share on other sites More sharing options...
[Ro...] Posted 13 hours ago Share Posted 13 hours ago Hi Owen, what issues do you mean regarding K-diagram for lead/helix? 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted 13 hours ago Author Share Posted 13 hours ago Please sign in to view this quote. It just won't put the lead K chart on the report. For whatever reason, the last time I run a K-chart on a lead, I had to make sure the report crown selection was checked for the K-chart to show on the lead. This time, it won't show on the report with the crown checked or unchecked. I know this is not the best explanation, just what I have in notes. I've also had issues with the profile K-chart not showing and had to delete it (uncheck it) and then click it on again (gratefully, it remembers the settings) then rerun the actuals and it appeared. I don't use gear-pro very much and just never have the time to submit a help ticket when I do. If you have any ideas as to why it is not working, it would be appreciated. Link to comment Share on other sites More sharing options...
[Ro...] Posted 13 hours ago Share Posted 13 hours ago Well, without ticket a potential bug can´t be fixed 🙂 Reagarding k-diagram no open issues or bug tickets are known. If you have the .act file I can try to have a look into it and check what could be the problem. 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted 7 hours ago Author Share Posted 7 hours ago (edited) Please sign in to view this quote. I appreciate your willingness to help Roman Grob, I finally got back on one of the gears today and without changing anything, the K-charts worked on both the profile and lead. The computer I'm working on is overloaded with cad, laser, ERP and a lot of other software running at the same time and that probably contributes to the problem. Edited 7 hours ago Link to comment Share on other sites More sharing options...
