[To...] Posted 2 hours ago Share Posted 2 hours ago (edited) Attached is picture of how to interpret 2 inline datum features in ASME. Does ISO or DIN interpret this in the same manner? I assume a stepped cylinder set to Outer Tangential would do the trick. Edited 2 hours ago Link to comment Share on other sites More sharing options...
[Ma...] Posted 2 hours ago Share Posted 2 hours ago I think new GD&T will do as picture shows. At least on Inspect i was looking at ISO for ABC and it was doing tangential plane - only way i found that was when i applied deviations on surface while ISO and Geometry it was showing 0.063mm flatness because of one sprayed hill on that A plane. So i assume you will be the safest if you use new GD&T and then compare it with you approach with alignment then datums to obtain same value. Link to comment Share on other sites More sharing options...
[To...] Posted 1 hour ago Author Share Posted 1 hour ago (edited) Please sign in to view this quote. I am working on a drawing from Germany and don't want to make any assumptions. Plus, I am using 2019 so new GD&T is not an option. I just want to know how other standards interpret Edited 1 hour ago Link to comment Share on other sites More sharing options...
[Ma...] Posted 33 minutes ago Share Posted 33 minutes ago On 2019 i would use stepped cylinder with gauss settings. I hope someone will pop up here soon i have to find info about datums. Link to comment Share on other sites More sharing options...
[To...] Posted 8 minutes ago Author Share Posted 8 minutes ago Why gauss? I would outer tangential in ASME. Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 minute ago Share Posted 1 minute ago OK so far as i found you will use tangential element - exception is usage of gauss for MMB. So i would use that stepped cylinder with OT evaluation - don't forget filtering and so on 🙂 Link to comment Share on other sites More sharing options...
