[He...] Posted 21 hours ago Share Posted 21 hours ago Has anybody flipped a part in the program and then tried using a free form surface after flipping? Calypso tells me "Not enough points" and wants to put the actual points in the original alignment and I can't seem to get this to work. I've got the features on the correct alignment. In the picture, I've flipped the part 180° about the X from the original alignment and I've recalled the curve points in yellow. I've also tried manually probing as well as using point sets. The issue seems to be the free from surface feature itself. Any suggestions? 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 21 hours ago Share Posted 21 hours ago I have no idea how far is your part physically moved in machine space, but you can try increasing search distance for points. Otherwise i would tryout adjusted alignment reflecting actual state. Link to comment Share on other sites More sharing options...
[Ze...] Posted 21 hours ago Share Posted 21 hours ago I believe that Freeform reads and extracts the nominals from the CAD model directly. Moving the CAD model may be causing your problem. Maybe use more than 1 model? 2 Link to comment Share on other sites More sharing options...
[He...] Posted 4 hours ago Author Share Posted 4 hours ago Please sign in to view this quote. This did not work. It put the points in the base alignment again. 1 Link to comment Share on other sites More sharing options...
[Je...] Posted 3 hours ago Share Posted 3 hours ago Please sign in to view this username. , Please sign in to view this username. is absolutely correct. The Free Form Surface (FFS) feature is unique in Calypso in that it is defined solely from the CAD model hierarchy. You're on the right path in troubleshooting. Focus on that window on the right side of the feature window underneath the trash can icon. This is the "surfaces" window. That is where surfaces from the CAD hierarchy will populate to show where the FFS is getting its nominals. There are a couple of things to try. First, make the model surfaces viewable. Then, click once on the icon in the FFS that looks like a surface with a magnifying glass. That activates the "surface picker." Then, click on the surfaces in the *second model,* to the right of your first model. You should see those surfaces populate in the surfaces window. If any unintentional surfaces populate in the surfaces window, click on them in the list and then click on the trash can icon directly above the surfaces window. This may be enough, or you may need to also you the "CAD model comparison" function, which is listed in the menu bar under "CAD." That function can be a way to attach features to a CAD model retroactively. One other sidepoint: make sure to save the measurement plan after you've imported the new model. That helps Calypso write the model to the measurement plan. Keep us posted on your progress. I'm interested to hear how this turns out for you. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago I've made this working by having two models placed same as a physical fixture. But that means you can not have overlaping models, so working area is bigger as for two parts. Now you have to go to join those two models as one. The easiest method is repairing model - this will join them as one CAD model, now it will know what is workpiece and FF will work. Only one thing - do a secondary alignment on a secondary fixture. Link to comment Share on other sites More sharing options...
