[Ri...] Posted February 27 Share Posted February 27 I'm looking for access to be able to set parameters for Temperature Compensation. I see that I can place parameters on which sensors to use and the coefficient, but I'd ideally like to be able to either turn on/off compensation via PCM, and/or set a part temperature via PCM. Link to comment Share on other sites More sharing options...
[Mi...] Posted February 27 Share Posted February 27 Please sign in to view this quote. getTemperatureCorrection().tempKorrOnOff // check if temp.comp. is activated getTemperatureCorrection().tempKorrOn // activate getTemperatureCorrection().tempKorrOff // deactivate 1 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 5 Author Share Posted March 5 Please sign in to view this username. I apologize for the late response, but thank you so much! I hate that once again something like this isn't documented in the Calypso PCM Operating Instructions. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 9 Author Share Posted March 9 Please sign in to view this username. Do you know if it is possible to force the .coefficientPart instead of placing a formula inside of the Temp Comp window? Link to comment Share on other sites More sharing options...
[Ri...] Posted March 9 Author Share Posted March 9 And it appears that unfortunately that the commands getTemperatureCorrection().tempKorrOn / getTemperatureCorrection().tempKorrOff do not work as needed. While they activate/deactivate, Calypso will show/behave in the state the program was last saved in - you have to open and then close the Temp Comp window for it to activate/deactivate properly. 😞 Link to comment Share on other sites More sharing options...
