Temperature Compensation
And it appears that unfortunately that the commands getTemperatureCorrection().tempKorrOn / getTemperatureCorrection().tempKorrOff do not work as needed. While they activate/deactivate, Calypso will show/behave in the state the program was last saved in - you have to open and then close the Temp Comp window for it to activate/deactivate properly. 😞
