Position
Hello guys,
I would like to ask if you could advise me on how to create this position in GOM Inspect 2022?
I have a problem with MMR.
Thank you for help.
image.thumb.png.cbf0574cf7f242a3de6cc1f091740e98.pngimage.thumb.png.6b7c72e83ac9feb6fc6eec37e640acd8.png
ISO 2692 up to 2014 version is saying, when there is maximum material requirement on tolerated features, it changes them to combined zone.
I cannot find exact paragraph in 2014, so please, if someone cares to share.
And I'm unsure how this changed in 2021 release, except that it forces explicit use of SZ and CZ.
EDIT: Paragraph 4.2.1, note 4 in 2014 version apparently
I tried it out and i also run into a problem 🫣
Is this the problem you get with MRR? "Every Element needs exactly one dimension of size for MRR"
Found the solution:
You need to build the linear size in a "special way".
Thanks Jochen,
for me is not problem create elements with MMR. But I'm not quite sure what the designer wants from me.
How would you create a datum system?
Thanks,
P.
Hi Peter,
I would ignore the MMR for the datum. When they want that funktion, they have to apply it to the datum system for a dimension.
For the datum itself ... It is unclear what the designer wants for me too. Maybe it would be clearer knowing the full part and the assembly.
