[Ma...] Posted March 3 Share Posted March 3 Hi Guys, Could you suggest what solutions you use for mounting many small parts on one pallet (e.g. small rotational parts – bushings, etc.)? I’d like to get some inspiration. Previously, we didn’t use the autorun option or measure multiple parts in a single setup. Photos of holders, fixtures, or links to manufacturers of such solutions would be welcome. Thanks in advance Link to comment Share on other sites More sharing options...
[Ma...] Posted March 3 Share Posted March 3 Depending on weight, size and magnetism. Running in an autorun is good for selecting nests, but using new PiWeb is more time consuming, then the old ones - so if you are concerned about time, then i would use more parts in one program. Or combination of autorun and many parts in one program ( like each nest would be one line of N parts ). We've used rubber pad and screw head on granite to place parts and perform quick measure of concentricity. 1 Link to comment Share on other sites More sharing options...
[Da...] Posted Saturday at 01:14 PM Share Posted Saturday at 01:14 PM If you have a 3d printer available you can print a fixture, nest, clamps etc that will hold your parts. That's how we setup "pallets" for some of our parts. You can always create a measurement plan to inspect your printed fixture if you think it won't be accurate enough. Link to comment Share on other sites More sharing options...
