export geometry to csv not possible
hi there,
since our last update from version 2023 to 2025 SP3, I can not export surface points to csv anymore.
warning text: MCADimport-0011 in explore is no valide element selected.
i select all surface points. And that works in 2023.
Does anybody else has such problem?
Hello,
In fact, I was able to export the surface points in SW2025 as normal:
after selecting the points in the expolorer:
for stage projects File -> Export -> Stage Data -> CSV
File -> Export -> Geometry-> CSV
Regards,
Mohamed
  • Like! 1
  • 2 weeks later...
Thank you for your answer, now I found the cause.
In last version i select firstly all the point in the naviagtion and then click to export - geometry - csv. and it worked directly.
after the update, i have to select to points after I opened the export windows ( the selection before is not taken over somehow). So i could not export because i didnt select any points.
  • Like! 1
