[Da...] Posted 11 hours ago Share Posted 11 hours ago Can you help me with seting up reports ? Where should i focus on ? I have to run old program for measuring blades, program is working but i do not know how to make setings right to have reports saved on disks. We have some programs working, but i'm doing some mistakes while trying to set it up like in thoose working ones. I need genereal pdf report and pdf plots. Plots are made based on some .ptx files, but the .pdf i'm not sure is it from Blade or Calypso generated Generally i tried to set up all poseable options in multiple printout to be like in working porgrams 1 - Use the same profile in every program so i think its not important 2 - Its called "presentation protocol (pdf with plots) 3 - After clicking on 3 i i see there are some patches using Header data with no option to change exact parameters. Do not know how to check exact what is used, but it seems to be used same Header parameters like orther programs so it should be ok 4 - Selected or not, it just let me put in header parameters on start 5 - Here i have some profiles but after recalculating from old measurements it does not give any changes. 6 - Those are programs from abroad, so characteristics names should be changed to have the same names like in other programs. (may the names cause problems ? ) 7 - There is also Blade icon in Characteristics so i jusst choose one of Blade specyfication files. Link to comment Share on other sites More sharing options...
[Al...] Posted 11 hours ago Share Posted 11 hours ago good morning Try clicking the button than i marked with a yellow circle Link to comment Share on other sites More sharing options...
