[Cl...] Posted Friday at 03:45 PM Share Posted Friday at 03:45 PM I had to edit a program. New rev, models, dimensions. So, I took it off the live machine and transferred it to my planner. I finished the edits, but to run it in simulation I needed to assign stylus. The only one I have on my planner is different from what the program uses on the machine. They do show up in red as (what I call) ghost styli. Is there any way to retrieve these offline rather than re-assigning them on the live machine? Link to comment Share on other sites More sharing options...
[No...] Posted yesterday at 09:38 AM Share Posted yesterday at 09:38 AM For a true simulation with collision detection you need to build your styli with the Stylus System Creator and import them (SSC) in Planner. Make sure you first import the correct master probe. Link to comment Share on other sites More sharing options...
[Cl...] Posted yesterday at 07:01 PM Author Share Posted yesterday at 07:01 PM This wasn't a new program. This was a program that I couldn't edit on the live machine, so I had to transfer it to my planner to edit it. I also needed to run it in simulation, so I had to assign the stylus I already had in planner. When I was done I couldn't retrieve the original stylus before I installed it back on the live machine. Link to comment Share on other sites More sharing options...
[No...] Posted 9 hours ago Share Posted 9 hours ago Do you mean you used a different stylus just for simulation, then wanted to go back to the original used on the live machine? What you could do is to export the stylus from the live machine as a PCF and import it in Planner. This way you don't have a stylus model (SSC), but all the tips with the correct names. Link to comment Share on other sites More sharing options...
[Cl...] Posted 8 hours ago Author Share Posted 8 hours ago I Forgot about that option. Thank you! Link to comment Share on other sites More sharing options...
