Hole Position deviations in report
Hi,
'hole position' is a dedicated check in I-Inspect. You need to check the Circle, slotted hole etc. with it. The values are shown in the label, when the 3D view is oriented to one of the directions (click on middle of cube or one of View -> Standard view in the menu, you may use a local coordinate system for viewing). When the 3D view looks good for you, create a report page with the camera symbol.
